Creo Schematics run bat files
PK_10809848
2-Explorer
Hello Support,
after installing Creo Schematics 9.0, when starting and closing the Creo Schematics application, our EDR software detects the .bat script that Creo wants to run every time. Each time it is a random name, for example "bg-hpul3.bat".
The file has a different name and SHA each time. The only common point is the file location, for example "'c:\users\username\appdata\local\temp\bg-hpul3.bat".
1. Do you know what the following script calls?
2. Is this script responsible for some Creo Schematics functionality?
Hi @PK_10809848
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team.
I have this massage from Carbon Black
FYI...We use a custom .bat file to start Schematics. This sets all of our directories, path to the Central Catalog, any Java scripts, etc. Maybe that's why it create one every time you open it up.
I don't know if this helps or not.
