Creo Simulate 2.0 and assigned mass properties
MartinHanak
In Creo Parametric 2.0 the assembly was created. It contains one special component with assigned weight (this information overrides computed weight).
  • Creo Parametric 2.0 reports correct weight of assembly
  • Creo Simulate 2.0 reports incorrect weight of assembly - it uses computed weight for special component instead of assigned one
Is Creo Simulate 2.0 able to use assigned weight of component ?
Thanks in advance for sending information .
Martin Hanak
Martin Hanák
I am not 100% positive but I don't believe so. You could add a mass simulation feature in place of your special component and correct the mass that way.
3 REPLIES 3
MartinHanak
(To:Chris3)
Christopher.
you are right. According to PTC Support engineeer "Creo Simulate calculates the mass based on the geometry and material properties only."
Case 12518029 https://www.ptc.com/appserver/cs/view/case.jsp?n=12518029
Martin Hanak
Martin Hanák
I would alter the density of the item to make the mass come out correctly, though this does not work right if the item doesn't have a uniform mass, such as a part standing in for an assembly of disparate density parts.
