I need copy a spec driven piping assembly that is repeated a dozen times in my design. The only difference is the component PID numbers such as the valve numbers will be different. Is there a way to change or add these numbers after I have copied the piping assembly?
Hi @KenMeeler,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
