I'm new here, hope to get the support I need with my first post.
As a designer engineer in rolling stock, I'm considering the use of Spec-driven piping within Creo Parametric 8, and working within EN standards I wonder if it is possible to define pipes with an alternative to the API schedule rating. For instance I got a copper pipe OD12 x 1mm thickness within EN 1057 which does not use schedule rating, so I don't know how to fill in the SCH_RATE in the Pipe Master Catalog csv file. Can I leave it empty? The alternative I thought is to fill the field with a made-up number/code but I'd rather to avoid this way. So does Creo Parametric Piping take in consideration piping out of API/ASME specs?
Thank you all in advance for your help!
Hi AntoDS
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry. Like the version details probably the Date-code as well could help.
Vivek N
Community Moderation Team.
