Creo View not showing "Skeleton" parts/assemblies
VeqTor
Hi all,
I have an ASM assembly here in Creo View with several PRT parts and some ASM sub-assemblies. One of the sub-assemblies doesn't load or show, as can be seen in the screenshot below:
https://i.imgur.com/ZtQNFLE.png
The same happens when that ASM subassembly is opened directly from Windows Explorer in Creo View -- and also when I load any PRT part of that subassembly directly to Creo View, see screenshot:
https://i.imgur.com/IcBiN7x.png
Here is a text comparison of the header of the not loading PRT part from above screenshot -- ("NoShow", left) with a part that loads without problems ("Show", right):
https://i.imgur.com/nL86QDY.png
Could it have something to do with the fact that the not-loading part (above left) is marked as "PART/SKEL_MODEL" in the header, and so probably is a Skeleton model?
If so, what would I need to obtain from the engineer in order to be able to see those Skeleton parts and assemblies in Creo View?
2 REPLIES 2
TomU
(To:VeqTor)
There is probably nothing in the skeleton models worth looking at in Creo View.  Usually these just contain datum features (points, planes, axis, and maybe some sketches.)
TomU
(To:VeqTor)
This article makes it sound like skeleton models are not normally published for viewing in Creo View:
https://www.ptc.com/en/support/article?n=CS211654
