Creo Welding issue
ptc-187142
Creo Welding issue
Howdy,
I have a issues regarding Creo's weldingwithin anmirror merge assembly and it's drawing. One, the weld features do not show up in the model tree (the components are there as they should be though). Two, this is afamily tabled assembly and there are instances which move locations and swap out component instances of which the welds (which are displaying and not failingon the generic and instances) do not follow and adjust to match the instances. Three, the weld symbols do not show up or are discovered withShow Annotations in the drawing (which problably is because the weld features aren't showing in the model tree I'm guessing). Has anyone run into this problem too? Does anyone know if there is there a Config option that's stopping the weld features from mirroring over?
Thx,
Matt Bracht
Senior Design Engineer
The GSI Group
0 REPLIES 0
