Creo crashes frequently blocking any operations to do.
taruchamy
I am using Creo Parametric Release 4.0 and DatecodeM100
Creo crashes often in a newly configured Laptop, other applications are working stable.
Couple of traceback were generated and it is attached along with Laptop configuration -
BenLoosli
(To:taruchamy)
What is the OS running the laptop?
How much memory does the laptop have ?
What graphics card is installed in the laptop?
What version of the graphics driver is installed?
If running Windows 11, it is not supported prior to Creo 7.
Article - CS348041 - Is Creo Parametric supported on Windows 11 (ptc.com)
