Hello all,
Hope you are doing well..!
I am facing a problem while opening creo since yesterday where a window is popping up. it is not allowing creo to start. see attachment.
Cersion--> Creo 7
please help..!
Br,
Sandy
How are you launching Creo? Are connected with VPN?
it appears as though you have lost a connection to your license server, I would contact your administrator, also check your firewall settings and make sure ports are open.
Please tell me how to check the ports if they are open?
does this mean that two days ago Creo worked and today it does not work?
Please run ptcstatus.bat and show its output.
in Parametric\bin subdirectory ... in my case it is E:\PTC\Creo7_050\Creo 7.0.5.0\Parametric\bin
@Sandy7 wrote:
ahh it is showing can't run 😑. see attachment.
it's strange. I have never met such situation.
