Creo tutorial: How to Remove Ghost objects
VladimirPalffy
In this tutorial, you can learn How to Remove Ghost objects from assembly - not stored ghosts anymore in PDM system:
This video was created based on question from a comment under my video on YouTube channel. Fell free to contact me or leave a comment, or idea for another Creo tutorial.
Vladimir Palffy - www.4kside.com
Tags: #proe #creo #creotutorial #tutorial #4kside #palffy #vpalffy #vladimirpalffy
Best Regards,
Vladimir Palffy
2 REPLIES 2
In the Replace dialog there is a check box for "Remember These Components"
If you uncheck the box, the old reference will not be kept.
I have changed my config option "remember_replaced_components" to no since maintaining the old reference is usually not important for me.
If you think you might put the old part back in, remember these components will allow you to replace the new with the old without defining the references.
VladimirPalffy
(To:kdirth)
Hi, thanks for your note but configuration option is:
REMEMBER_REPLACED_COMPONENTS YES*/NO (where * is default)
Best Regards,
Vladimir Palffy
