Creo1 and PDF troubles
rrich
2-Explorer
Ok so I have a few questions.
How are you all making PDF's right now? In WF4 we use to use this icon.
[cid:image001.png@01CDA542.639339F0]
Now in Creo1 I have seen the quick save as pdf button and I found the export settings page but things are not working the same. PDF does not recognize the creo blueprint font. Well, let me restate that. When I print and run through Adobe distiller I get the pdf that is attached. When I use any of the PDF functions inside of Creo1 it tells me PDF aborted.
So does anyone have any words of wisdom.
Ron
Hi Ron,
Have you tried exporting the pdf using the pdf settings? We see a much better output when we select "stroke all fonts" under the Content tab. You can save a profile as well so you don't have to set each option every time. Hope this helps.
Rich
