Creo 10 Pro/Toolkit developement. How to route multiple cables through a network?
I tried following code to route all cables through the network point. But all cables are concentrating in one point as the attached picture shown. It is not what I want.
Make sure that the location is defined as "Flat" and you can then change the "Packing" of the location.
Hi @KJ_9759172
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
