Hello everyone,
I am working with Creo Parametric 12.4.2.0 and I want to export a .dxf file from a drawing, using:
File > Save as > Export > DXF
I usually use a sketch or a solid from a .prt file and place it in my drawing to do so. This works perfectly fine in Creo 3 and 6.
My problem is, that whatever is contained on my drawing, gets turned into a image, when exporting it via Creo12.
So if I open the .dxf file in another software, I do not have single splines or curves anymore, I have one big, very blurry, image, as seen on top here:
What have I tried:
What I found out:
So I assume something goes wrong in the communication between .prt and .drw.
I have checked the config options, but so far I have found nothing that sounds like it would fix my problem.
Does anyone have experiences with this or may know a config setting I could try?
Every idea is very welcome - thank you very much!
Is it possible that you are placing the view as a shaded view in Creo 12? That would make it an image.
If it is a no hidden lines or wireframe view it should export out as splines.
This was it, thank you so much!
I tried it and it worked.
I also cross-checked with Creo 6 again and saw that even if the part is shaded, the view on the drawing is automatically set to "wireframe". This is still missing in our Creo12 set-up, so I will go searching for this setting now.
Again - thank you so much for your help!
Edit: if somebody comes across this problem in the future, the config setting is:
enable_shaded_view_in_drawings -> no
It's not an elegant solution, but a possible way to get the DXF you need might be to select the view, then use
Edit -> Convert to Draft Entities
This will take all the stuff that's visible in the view and render it into a bunch of "dumb" curves. There's no going back to the regular view after doing this, so either don't save or do the work with a temporary copy of the drawing.
Sorry I can't try this stuff with Creo 12, we are on Creo 9.
