Creo2 : Customization note in drawing mode
ldrutel
When i create a new note with an arrow, automaticaly the note appear with the reference line on the top of this note. Is it possible to specify that I want the reference line at the bottom of the note ?
rcook
(To:ldrutel)
If you don't want the note underlined like what happens when you "Toggle Leader Type", you can also add "@O" at the beginning of the line that you want the leader to go to.
On left is "Toggle Leader Type". On the right, there is an "@O" in front of "LINE 3".
4 REPLIES 4
Select your note then RMB and select "Toggle Leader Type"
rcook
(To:ldrutel)
ldrutel
(To:rcook)
Great, thank you
Mahesh_Sharma
22-Sapphire I
(To:ldrutel)
Laurent,
You may mark Roger's reply as correct answer for the post.
