Creo3.0 M070 efx failed to load
afeng-2
2-Explorer
在重新部署新的版本Creo3.0 M070后每次打开都有这个错误对话框
请教。。
18606279656
2 REPLIES 2
RichardJ
(To:afeng-2)
Ryan Kelley‌ could you please move this to the Creo forums.
Hi Andy,
I did a search in the internal TS database, for the error message and found an article that suggested to set the config option afx_enabled to no.  Please give this a try and see if it helps.
CS185042 - Expert Framework Extension was failed to start with error“efx failed to load” in Creo Parametric 2.0
If you are unable to view the article, you can create an account here.
Amit
