Good morning, I am fighting with a very basic issue : I appreciate the result of shading mode with reflections versus the normal shading, but : a) I need to hide the floor reflections ( I need just the surface part reflections ) b) I need to set the reflection plane as the yellow plane Do you know if/how is possible? thanks
It is unclear to me exactly what you mean by setting the yellow "surface" as the reflection plane.
I will take a guess that you mean the yellow surface is sitting on the floor.
VIEW-Scenes-edit scene - environment
Change the floor plane (only planes in the world coordinate system will be allowed)
If you want to do internal reflections you need a special license for Advanced Render. (Applications - Render Studio) By internal reflections I mean you can have a part or surface reflect off another surface and/or create shadows part to part. It is an advanced rendering mode because this requires tracking rays of light bouncing off multiple surfaces. It can also by the way do refraction through transparent/semi-transparent materials.
In the "reflections with shading" that comes standard only the "Room" environment can reflect or have shadows and only as "Ground effects" or reflections of the room off the model.
Hopefully that clears some things up if you had not already received help through other channels.
