Creo4 Config.pro online_resources_location not working for custom help center location
LawrenceS
18-Opal
The config.pro option online_resources_location is not effecting the default Online resources.
As a test I changed this option to:
online_resources_location https://community.ptc.com/
But when I open "File: Help: Online Resources" it still goes to the default location, which I think is:
https://www.ptc.com/en/creo/start-page/wildfire
Am I doing something wrong is is this just broken?  I have never used this before.
I am using Creo4 M140.
"When you reward an activity, you get more of it!"
To summarize the answer:
  • I was using this option correctly and it was actually broken.
  • With the help of this post, it was reported to R&D as SPR 13259094 with Article summary CS354119
  • PTC Plans on fixing in following versions:
    • Creo Parametric 7.0.7.0
    • Creo Parametric 8.0.3.0
    • Creo Parametric 9.0.0.0
Thank you to all those that helped to find and correct this issue (Users and PTC).
6 REPLIES 6
according to https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/index.html#page/fundamentals/fundamentals/fund_one_sub/fundamentals_configuration_options.html  page ...
<directory path>
Sets the path to Online Resources. When you click Help > Online Resources, Creo Parametric launches the Online Resources page from the specified location.
Martin Hanák
That sounds like what I did and it didn't work for me.  Is the custom location working for you?  When I set:
I see essentially what you sent in your screenshot.  I get to Creo at the moment so cannot send a screenshot of what I am seeing so will try to send a screenshot when I can.
Here is my screenshot:
Even though I have this line in the config.pro in my working directory:
I did quick test ... and it seems to me that config.pro option online_resources_location is not linked to a Online Resource command (it opens http://www.ptc.com/community/creo4/parametric page which is redirected to https://www.ptc.com/en/creo/start-page/4 page).
Please ask PTC Support.
Martin Hanák
Thanks for verifying that it is not working for you either.
