I am using Creo Parametric - Release 6.0 (connected) Release 6.0 and Datecode6.0.6.0
1. I am using the config.win and creo_parametric_customization.ui, where the mapkey applied icon is stored, in the starting location.
2. If delete Config.win, the icons will be changed to smiley icons.
3. Please tell me how to not change the existing icon to a smiley icon even if I use only creo_parametric_customization.ui without config.win.
Translated with Google Translator by Hedy Jin on Jul 7, 2022
1. 맵키가 적용된 아이콘이 저장된 config.win과 creo_parametric_customization.ui 를 시작위치에 같이 넣고 사용하고 있습니다.
2. Config.win을 삭제하면 아이콘들이 스마일 아이콘으로 변경됩니다.
3. config.win이 없이 creo_parametric_customization.ui 만 사용해도 기존 아이콘이 스마일 아이콘으로 변경안되는 방법을 부탁드립니다.
Most likely cause: Your creo_parametric_customization.ui does not have the icon definitions in the file. Migration of config.win settings to the new .ui file is probably not supported so you will have to do this manually.
Assuming your old conifg.win file assigns the icons you want then you will need to load the config.win and then copy the icons into the creo_parametric_customization.ui file.
Use a Creo release (Creo 5 or earlier ?) that allows for both conifg.win and creo_parametric_customization.ui to be loaded. Once you load the config.win and verify the icons are assigned then you will need to copy the icons to the creo_parametric_customization.ui file.
You can do this by following this process:
The .win file to configure the User Interface with Creo has been discontinued and you need a solution to keep show custom icons for your mapkeys.
When searching the knowledge base with the following keywords: mapkey icon .ui, you will find the article below.
https://www.ptc.com/en/support/article/cs28612
Can you confirm you applied it? and confirm that despite that the icon reverts to the smiley?
