Is it possible to create a custom hole file (.hol) for holes that are only drilled, not tapped? I'm trying to recreate a standard drill chart with our standard countersink sizes and hole callouts.
For the life of me I cannot figure out if Creo will allow me to do this. I have a number of custom threaded hole files but this one is an enigma.
What I have so far is attached. When I go to select a size from it, I just get a -1.000 for the diameter. Remove the .txt if using the file.
Thanks..
I don't know what fails with your hole table (I think maybe negative values are not allowed???)
But I have a similar table so maybe have a look at mine and see if it works, and if so, maybe copy the format...
Thanks for the file. It helped me figure out what I had incorrect in mine. In general I removed the negative ones from the columns.
