Custom simulation report?
Chris3
Is there an automated way to export a series of images for the results
window? For instance if you were running a modal analysis and you want
to explain the shape in a report, it's nice to have a series of images
showing the motion. Right now I manually step through each frame and
export it as an image.
Yes I know I could export it as a movie, but you can't print out a
movie.
I thought I had read somewhere that you could generate a custom report.
I am thinking that the default report includes an image so maybe there
is a way to make it out a series of images to show the modal shape.
I also thought about using a mapkey to do this, but they aren't
supported in the results window.
Hope this helps
Don Anderson
