Cut out in boolen operation_Must we need solid body
ptc-5398568
8-Gravel
For cut out in boolen opertion must we need two solid bodies? Can we do this from cutting surface body from solid one.
I have one surface model & I want to cut out from solid ? is it possible?
Attached file is my query.
I want to cut that surface part from solid part in assembly.
so that that will create die of that surface part . and I have only that surface part and I cant convert that into solid.
if I have both solid part then I can do this. but because of having one surface and one solid I'm unable to do this.
could anyone pls suggest solution?
1.] Create cut out feature ... it enables you to copy quilt representing surface model into solid model.
2.] In solid model create Solidify (Remove material) feature. This feature enables you to subtract volume represented by quilt from solid geometry.
Martin Hanák
Hi Sir,
Attached my query ,
if I have both solid part then I can do this. but because of having one surface and one solid Im unable to do this.
Now could you pls suggest solution?
@ptc-5398568 wrote:
Hi Sir,
Attached my query ,
see my previous reply. You can also try reparing your surface model.
Note: I cannot provide anhy other suggestion, because your problem is probably "data dependent".
Martin Hanák
You can copy the quilt into your part using Copy Geometry. Then use a Solidify to cut the material.
