Cylindrical grinding
bprazak
Hi
Would someone know how to make a set-up for cylindrical grinding in manufacturing module?
Is this mill-turn? The rotation axis of cutting tool is parallel to axis of workpiece.. Thanks for clues!
Currently using turn operation having turning tool instead grinding wheel.
GabrielZaha
(To:bprazak)
As long as the current setup is giving you the correct program I don't see anything wrong using a turning operation.
If you want/need to use a milling operation, you may consider the grinding wheel as a side-milling tool
