DEF_DENSITY no longer works in Creo 8
Hi there,
My company updated to Creo 8.0.1.0 some weeks ago. Now it turns out, that the model check test "DEF_DENSITY" does not work anymore in Creo 8.
In Creo 8 every part gets the default material "PTC_SYSTEM_MTRL_PROPS", which has the density of 1.0.
The test DEF_DENSITY should check, if the density is 1.0, but the test passes.
Since we use modelcheck as a gatekeeper for our windchill, there is a pretty chance, that the pdm-system gets filled up with neutron-star-like parts.
Does someone knows a workaround?
