DEFAULT_CALLOUT_FORMAT_DATA
  • January 30, 2021
  • 8 replies
  • 4246 views
As soon as I add "DEFAULT_CALLOUT_FORMAT_DATA" to the ISO.hol file, Creo 5.0.6 does not open that file and is not visible in hole dialog. I do not add anything else. Anyone knows why this is happening?
did you read http://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/part_modeling/part_modeling/part_nine_sub/Formatting_Thread_Notes.html page ?
Please upload your ISO.hol file.
Hi Martin.
Yes, I did. And everything started from there. I made file like what it says in mentioned link but I got into problem hol_1 file not showing up. At first, I though because I use Notepad++ and CR = Carriage Return and LF = Line Feed and how Creo reads text file (in this case hol file) is where the problem lies, but it is not.
Then I realised that as soon as I add DEFAULT_CALLOUT_FORMAT_DATA Creo does not show it in hole dialog. I did the same for ISO.hol and same happened.
I'm not sure this is the issue, but in your sample file, the table that defines the callouts is missing.
The line DEFAULT_CALLOUT_FORMAT_DATA should be followed by callout specifications.
You can specify a different callout depending on hole configuration.
Can you load in the hole table if you modify your example ISO_1.hol and add these 2 lines:
HOLE_TYPE THREAD DRILLED_DEPTH THREAD_DEPTH CSINK CBORE EXIT_CSINK CALLOUT_FORMAT
TAPPED YES NA NA NO NO NO &DIAMETER[.3]
(also, I think reloading .hol files requires Creo restart)
