DESIGNATE PARAMETER MODELCHECK
cspinelli
hello,
is it possible to designate parameters already present in model via Modelcheck?
it seems not working...
thanks
Yes, It is working for me.
I have set it as below.
PRT_PARAMETER parameter_name STR EQ *
PRT_PARAMETER parameter_name STR EQ PDM
16 REPLIES 16
cspinelli
(To:Mahesh_Sharma)
thanks,
but if i have already parameter in the model, ModelCheck Interactive will not designate the parameter.
i have only STARTPARM set to ERROR in *.MCH file, is it correct?
I don't think it will create any issue in that. Share your Modelcheck config files, that may help to check the cause.
cspinelli
(To:Mahesh_Sharma)
ok, please find attached
Worked for me. Checked for of the parameters
DENOMINAZIONE
DESCRIPTION
LAST_MODIFY
Try Setting MU_ENABLED as Y in Config_Init.mc.
cspinelli
(To:Mahesh_Sharma)
set MU_ENABLED to Y then opened a file and its like this:
then MODELCHECK INTERACTIVE and there is no change...
Strange.....
I did the same thing and results were as in image. One difference here is value of Last_modify in my case it is * and in yours it is -.
cspinelli
(To:Mahesh_Sharma)
strange indeed...
i've accepted your first solution, thank you very much!
but could you please do a last check? could you remove the flag to LAST_MODIFY for example and then redo MCInteractive?
I did and it worked.
I did a test by adding a parameter LAST_MODIFY with soem value and run MC Intractive and that desiginated the parameter. I think instead of Uncheking Desigination, remove and re-run MCI
cspinelli
(To:Mahesh_Sharma)
fyi,
i've contacted support.ptc.com and the problem was missing PARAMCHECK YN Y in *.mch file
Thanks for sharing the info.
If still it doesn't work, submit a support case for PTC. They will be able to debug this.
Hi All,
I am working for implementing creo model check for my projects, having few questions regarding setting up the parameters.
1) I need to set up the below listed parameters I have added these files in my start files but it is not working.
  • Description_1
  • Description_2
  • Description_3
  • Material_1
  • Material_2
  • Material_3
  • Drawn By
  • Checked By
  • Engineered By
  • Part Number
  • Drawing Number
Can any one help me how to configure these parameters? I have added in my start files as listed below but it is not working.
PRT_PARAMETER DRAWN_BY STR EQ *test*
PRT_PARAMETER CHECKED_BY STR EQ *test*
PRT_PARAMETER ENGINEERED_BY STR EQ *test*
PRT_PARAMETER DESCRIPTION_1 STR NEQ *test*
PRT_PARAMETER DESCRIPTION_2 STR NEQ *test*
PRT_PARAMETER MATERIAL_1 STR NEQ *test*
PRT_PARAMETER MATERIAL_2 STR EQ *test*
PRT_PARAMETER MATERIAL_3 STR EQ *test*
Naidu
cspinelli
(To:ptc-4779205)
hello, in my modelcheck i have these settings (part of) and theyre working. dont forget to set PARAMCHECK Y in *.mch file PRT_PARAMETER DENOMINAZIONE STR EQ * PRT_PARAMETER DESCRIPTION STR EQ * PRT_PARAMETER LAST_MODIFY STR EQ *
