All dot lines (center line, axis, dotted line, etc.) appear as solid lines.
I reinstalled and overwritten the config file and setup file with the existing ones.
Before re-installation, it appeared as a dotted line properly.
Hello @BK_8551144
Seems to occur in 3D Mode as per your snapshot ('Part and Sketcher environment). May this be due to Units configured - eventually different from the units you have the habit to work on?
Serge
Thanks for answer.
The unit is using a normal mmKs unit.
The same phenomenon appears not only for new parts but also for existing 3d/2d models.
When I run the same file on a colleague's computer, it appears as a normal dotted line.
It only appears as a solid line on my computer.
And also the path and file of template_solidpart are not missing either.
Hello @BK_8551144
Thanks for those verifications and feedback. Seems that everything is then configured properly in the impacted machine. I searched our Knowledge Base but was unable to locate any relevant case/article/SPR dealing with this unexpected behavior. Some ideas come nevertheless to me as follows for the troubleshooting process:
First test suggested:
Second step suggested (based on outcome of test above); If issue persists:
(You may want to have a look at it in parallel as well)
Serge
I don't want to reinstall.
It is too cumbersome to set up again.
When I checked, only DOT_CTRL_FONT came out as a solid line.
All other dotted line types such as CTRLFONT_MID_L and CTRLFONT_S_S are displayed normally.
