DRAFT help - solved...
A.DelNegro
7-Bedrock
Thanx for all the help people. This is what I had intended but for some reason Pro wouldn’t let me use the plane to split the draft. When I tried it again it worked.
Doing each side one at a time worked well too but since my actual part is much more complicated on the top, using the first technique was better.
Thanx again,
Tony
0 REPLIES 0
