I typically import DXF in to a part and then use that to create creo sketches from. I don't ever extrude directly from the DXF.
Just a quick glance at your images and I have no idea if it will work for you.
How do you create the sketch from the DXF file?
Here are the steps I followed in order to produce that part...
I opened your model (ARMS_CROSSED.PRT) and I put a white background body behind the solid you created as per above, and the result is pretty close to what you are trying to accomplish (Screenshot_arms_crossed_03.jpg) - isn't it?
Please clarify what is the problem with the extrude.
The DXF import curves are definitely a different type. To color the imported curves, you should window select all of the curves and, from the RMB menu, select properties then change the color.
Coloring the extrude surfaces act normally for me.
How do you color the imported curves?
I do not understand how I should window select all of the curves and then select properties and change the color...
Move curser to top left of screen.
Press and hold left mouse button
Move curser to bottom right of screen and release left mouse button. (may take a while for all of the lines to select)
Long press right mouse button
Select Properties from pop-up menu
Select the color button
Select a color
Select OK
Select Apply
Select Close
Hi @cgherghe-2,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
