Datum Plane Pattern
davidlawrence
Datum Plane Pattern
Gurus,
I'm trying to create a datum plane between the axis of a hole in a circular
pattern and the axis of a hole in a rectangular pattern. Using the 2 axes as
the references creates the plane. However when the datum plane is patterned
it only uses the first axis picked as the reference. Anything I'm missing?
David Lawrence
Mechanical Engineer
301.552.6300, X 124
www.sigmaspace.com
David,
a reference pattern can only reference one pattern, which is why you
second axis stays the same.
Bjarne
"David Lawrence" <->
10-03-2009 15:49
Please respond to
To
cc
Subject
[proecad] - Datum Plane Pattern
Gurus,
hole in a circular
as
patterned
David Lawrence
Mechanical Engineer
301.552.6300, X 124
www.sigmaspace.com
