Hi all,
I ask the community before PTC...
We use CREO 7.0.2.0.
We use datum point in a sketch, to figure location of several concrete mass.
We put an hole table, edit the point tag according the CS21713 tips
But in the drawing, we would like to show them using a leader note for making a visual link between the hole table and the view.
How can we retrieve the point name in the leader note?
I try the &Name but it doesn't work.
Second question:
In the table hole, can we use relation, like in repeat region?
We would like to use a relation in order to simplify the name of each point.
For example:
Point name : 001_SE08_114
Point name simplified : SE08
Regards
in https://www.ptc.com/en/support/article/CS133915 document you will find system parameters applicable in drawing. Unfortunately parameter representing feature name does not exist. You can create leader note containing &mypar:att_feat string if you add parameter mypar to specific feature.
Thanks Martin.
It's clear.
