I'm having an issue with my datum filter not showing anything such as planes or coordinate systems and points. I have them checked and have show annotations but that gives me an error of "No annotations can be shown for the selected objects.". I'm using Creo 4.
Any help would be appreciated.
On the view tab, check that the datum are set to show.
Also in the view tab, select the Layers button to view the layer tree.
Unhide the appropriate, or all, layers.
I would have never of looked there, thank you!!
