Datum tag overlaps with Gtol in Creo 5
mhill-2
Hi All,
I'm relatively new to Creo/ProE, so this may be a somewhat trivial question
We just converted from Creo 2.0 to Creo 4.0 a few weeks ago, and I'm having problems adding a datum tag and geometric tolerance to the same dimension in the new program. More specifically, when I try to add an ASME datum tag and a flatness geometric tolerance to the same thickness dimension, the symbols overlap with one another.
What's really strange is that I was able to do this in Creo 2 without any problems. The images of the drawing view from Creo 2 and Creo 4 are shown below
In Creo 2, I used the model datum button to create the datum symbol, but in Creo 4 i'm trying to use the datum feature symbol button, so I wonder if that is part of the reason for this problem. Alternatively, this form of dimensioning may not be appropriate anymore with the latest drawing standards
Any help would be appreciated
Thanks!
-Matt
0 REPLIES 0
