One response and it wins! Thank you Mr. Frindt! (hope you don't mind my
mentioning of your name).
Put a decimal point and the number of decimal places in square brackets,
like this
&PARAMETER_1[.5] - this will display in 5 decimal places (1.00000)
&PARAMETER_1[.2] - this will display in 2 decimal places (1.00)
We applied this to the bom table row of one item that was part of a
family table.
All instances changed to 2. Not sure if that is good or bad?
I first tried to add to the model. But it worked in the bom in the
drawing.
Then I thought...maybe it can be added to the repeat region text itself
that runs the bom description.
I will need to save that for another day ... as I have a hot job to
finish. I was actually helping a fellow worker.
Thank you sir,
WayneF
