Default Font?
erine
Default Font?
Hello all,
I've used these boards for a while but never had to post a question.  I'm stumped on setting the default font settings within a drawing.  What I mean by that, is that when I create a new drawing or add a new dimension, note, ect in an existing drawing, it is not set to what I need it to be per company drawing standards.
I need my font to be "font."
My config file includes:
default_font ---> font
pro_font_dir ---> C:\Program Files\PTC\Creo 3.0\M110\Common Files\text\fonts\
The folder that pro_font_dir points to does not have "font" as an option.  They are all .TTF fonts.  Is "font" not an actual standalone font file? This brings me to an additional question:  When I'm in a new drawing, my default font is set to "CG Triumvirate" in Dimension Properties, ect.  I cannot find a setting within my config file that contains this, so what am I missing here?  There must be an additional setting somewhere driving this, correct?
Any help would be appreciated.
-Thanks
Creo 4.0 / M060
BenLoosli
(To:erine)
Drawing fonts are set from a *.dtl file, not config.pro. Look in the Help File Collection for the Detail.pdf manual or online help for detail.file.
'Font' seems to be a built-in font. We went away from it as it does not differentiate between a lower case l and a numeral l. We use IsoFont which is better.
2 REPLIES 2
BenLoosli
(To:erine)
erine
(To:BenLoosli)
This seems to have worked!  After changing the setting in the .dtl file, I created a new drawing.  Dimensions and notes are at the correct settings.  Same thing happens when I alter or add new dimensions/notes in an existing drawing.  Thanks!
As for "font" not being the best, I know what you're saying but the powers that be, won't budge on some issues.
Thanks again!
Creo 4.0 / M060
