Define ECAD_REF_DES for component in subasm
CHENAMA
Hi Community,
Creo version in use 11.0.2.0 connected to Windchill 12.1.2.10
Does anyone here know a way to define a reference designator for a component used in a subassembly in the upper Assembly?
Our use case:
A - Top Assembly,
  B - Subassembly (Gathering Part)
    C - Component with an electrical designation e.g. R101
    C - Component with an electrical designation e.g. R102
Subassembly B is used several times within A, but it's actually just a "dummy" assembly which only exists in MCAD. When we now assign a reference designator for C, it is defined in B, hence it's always the same, but it should differ. Is there anything foreseen in Creo / Windchill to cover this?
Follow up question would be if it's somehow possible that component C immediately appears in the WT-Part structure of A without generating a Part for B?
Thanks and BR
CHENAMA
(To:CHENAMA)
If anyone else is wondering or looking for a similar functionality.
We found groups to work quite well.
You can copy a group and when using paste special with Advanced reference configuration to work very well. In there you then only have to re-define the constraints which are set to outside the group components. So, it allows re-using groups, while defining usage attributes such as Reference Designator per item. Further of course you can also pattern groups within an assembly.
5 REPLIES 5
tbraxton
(To:CHENAMA)
If you are asking if the refdes could be assigned automatically, the only way I know that would be possible is when importing using the IDF interface where the ECAD_hint.map file maps the component during import and uses the refdes from the IDF file imported.
You can manually assign the refdes using the methods shown here: Article - CS53637 - How to create ECAD Reference Designator for components in Pro/ENGINEER and Creo Elements/Pro assembly
Involute Development, LLC
Consulting Engineers
CHENAMA
(To:tbraxton)
No I'm not looking for a way to automatically assign the RefDes automatically. I am looking for a way to define the RefDes in Assembly A for components which are actually used in Assembly B.
A - Top Assembly,
tbraxton
(To:CHENAMA)
Using your provided assembly notations above.
In assembly mode with Assembly A as the active model if you then activate the component C you should be able to follow the process to manually assign the refdes to component C.
CHENAMA
(To:tbraxton)
yes, that works, but then I can't assign two different RefDes for the same component, as I set it on assembly B or on the component C but I want to set it for component C in Assembly B in Assembly A.
CHENAMA
(To:CHENAMA)
