I'm trying to define various Pro/E launch commands in Intralink 3.4, and I can't seem to get them to work. The batch files work and launch Pro/E fine outside of Intralink, but when I define them as a command within Intralink, it does not work. The only thing I see is the pop up window stating that Pro/E is starting, but it never does. Can anybody help me out with this one?
Rob Devaux
Sr. Tool Designer
ABA-PGT, Inc.
10 Gear Drive
Manchester, CT. 06042-0270
United States of America
(860)649-4591 ext. 120
fax (860)643-7619
rdevaux@abapgt.com
www.abapgt.com This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
During the installation of Pro/INTRALINK Client did you make sure that you properly specified the location of the Pro/ENGINEER installation?
Make sure you specify proe.exe as the startup command rather than a specific startup command batch file. This way Pro/ENGINEER will bring up a small dialog box where you can choose which command to use.
