Hi all,
After an upgrade in a drawing template, where i updated/deleted some symbols, annotations and change fonts.
But, it seems that an old fonts is still present, because i have the message "***.ttf.ndx is not loaded.
But for me, the annotations/ symbol which used this one are deleted.
How can i purge the drawing template for all the fonts unused?
I tried the options upadte_drawing all, the delete unused symbols options but without success.
How can i clean my drawings template for unused fonts?
1.]
Check detail configuration options in template. Search old font name in the file.
2.]
Annotate tab > Annotations group > Define Symbol > Delete > Name
3.]
Upload your template to enable others investigate its contents.
1.]
2.]
3.]
Thanks Martin,
But I can't find the font in the detailed options (dtl file), and the symbol that contains the font has already been deleted.
I think i need to open a ticket 🙂
it looks like your template is secrete one and you cannot upload it ...
Not secret 🙂
But i tooak a breathe, remade your proposal on one of my template and it worked.
So i applied it to the other 4 and the unpleasant message disppeared.
Thanks again.
Regards
Dom
Has the font been removed from all tables, table cells, notes, etc.? If the font, in the format tab, says "As Is" there may be several fonts in it
