Depency simmetry doesn´t work for sheetmetal reliefs
ereguera
7-Bedrock
I am using Creo Parametric 7.0 7.0.3.0
In a sheetmetal part, I do a flange with a rectangular relief, then i do a simmetry of the flange, if i change the relief from rectangular to another else the simmetry flange doesn´t change the relief, it´s keeps in rectangular relief, Why is the reason?
Hello
Please refer to Idea 470896 Mirror in Sheetmetal should update mirror flange/flat reliefs as well.
https://community.ptc.com/t5/Creo-Parametric-Ideas/Mirror-in-Sheetmetal-should-update-mirror-flange-flat-reliefs-as/idi-p/470896
If you need more information, you can request for a case to be opened.
Best regards
Jean Claude
Mirror feature option Fully dependent with options to vary would be needed which is not available in Sheetmeltal: https://www.ptc.com/en/support/article/CS166281
