Hello Everyone,
I'm planning to upgrade Creo 11, I noticed some config option are depreciated in Creo parametric 11 from my existing config.pro file.
may I know the new config option for below ones.
Thank you
Kumar
These options are not in config.pro but in your detail setup file (.dtl).
Mapkeys have all been moved to Mapkey.pro.
Not sure of this one
Windows Browser type is set by default to Chromium since Creo 9 and IE is no longer supported so the option is not needed
Thank you for your quick response,
Still I have one confusion if something we configured in .dtl file then why it is showing invalid command in Creo configuration option.
Kumar
Settings in .dtl are for drawings, or .dwg files. When you create a drawing they are the defaults.
Settings in config.pro are program options. They affect overall Creo operation.
They're two different things entirely.
Hi Ken,
Thanks for you reply.
That means even if we remove options from configuration editor OR config.pro file. Drawing will work according to the defaults Settings in .dtl.
Please correct me if am wrong.
Kumar
Kumar,
That is correct.
For future reference, this site provides a complete list of config.pro options for each Creo major version:
Particularly useful if you want to set options that are hidden.
