Hello!
How to designate component's level parameter EFX_ITEM_NR for PDM?
Hi Yaroslav Sinitsyn,
yes you can designate the parameter.
Go into your AFX -> Configuration folder. In this folder you will find a file called _hidden_options.cfg. Rename that file to hidden_options.cfg and add the following line to it:
EFX_ITEM_NR_DESIGNATE YES
After that setting the item number will be designated.
greetings Sam
greetings Sam
Thank you!
ps: I'm curious why used hidden options for really cool stuff? Why hidden? ![]()
