Determining the right Mechanism in creo
CC_9824097
I have 2 parts as shown below, ive made the parts so that the top sits flush with the bottom part. I want to be able to pivot the top part slightly so Its angle changes only by a couple of degrees either side. I've tried to use the cylinder mechanism however because my shape is more of an oval than a sphere, a collision occurs when i pivot the top part.
Are there any other mechanisms that might work for this situation in order to pivot the top part without collisions?
Thank you in advance!
2 REPLIES 2
Have you tried using a pin constraint? That seems like it might be what you're after. You can limit the rotation to avoid collision.
If both of them are oval, and both are a different oval (the upper one having smaller major axis) so one can move on the other (Am I right so far?), you'll have to use application->mechanism->CAM connection. Then either you enable collision detection on your assembly (which may or may not work depending on your luck mostly), or you set and angle offset constraint.
