Did you know that you can use the ifx_translation.txt file to translate your label and help text in the IFX Fastener Definition dialog?
The file is located in <IFX loadpoint>\text\<LANG>\ifx_translation.txt
You can translate
For each catalog/*.dat name you can add a label and help text as described in the list below:
The example shows how to add a translated label and help text for the ISO4014-5_6.dat fastener data file for german.
ISO4014-5_6.Label
ISO 4014 - 5.6 Steel
ISO 4014 - 5.6 Stahl
ISO4014-5_6.HelpText
ISO 4014-5.6 (DIN931) Hexagon head screw with shank\nproduct grades A and B
Sechskantschraube mit Schaft\nProduktklassen A und B
