from time to time there is the question on how to add a second nut in IFX. Well, by default this is not possible. But you can use the following workaround.
I will explain it by using the IFX nut ISO4032-6.
Add a new icon for you new nut. Size should be 32x16 pixel.
Now add this new nut to your catalog. I have added it to the mm catalog to a new group 'second_nut'. If you want you can add a icon for this new group. Simply copy the attached 'second_nut_icon.png' to the 'ifx_catalog' folder in your IFX installation.
If you now start Creo, you can use the second nut in the 'Side 2 Washers' area.
I hope this post will help you adding your second nuts. Find attached all necessary files.
