Hi!
I'd like to make a resistor artifact in schematics 3.0. Is there a way to add both a European and an American circuit shape to it with the same ports and same name? If I put or copy the ports It always increments the name value by one, so on one shape it would be 1-2 on the other 3-4... The question is interesting in the x-ref shape area too, because if I'd like to make a cross reference shape of something it would normally have the same pin numbering than before, I cannot manage this now. How should these suppose to work out?
Thanks!
Laszlo
Laszlo,
Use "reassign shape" on the port when you create the shape. This way you re-use the ports from the other shape.
Laszlo,
Jeff!
Thanks for the fast answer again! I've quickly tried the reassign shape option, it works fine! Thanks again!
Regards!
Laszlo
