Dimension Line & dimension text
ptc-1112947
Hello, Can anyone tell that how to change the dimension line as thin in the printout and dimension text as thick. Now if i make the changes in dimension text, the dimension line also gets changed. I want dimension line as thin line and the dimension text as thick
Hello, there are an option in the drawing config named line_style_standart that changes the colour of the text in a diferent way that the colour of the arrow. It may help you.
Hi dinesh,
You have to set properties in
PUBLISH----> PDF-----> SETTINGS
next
This settings may fulfill your requirements.
