I met a problem with Creo 7.0
I copy an old part&Draw too made some changement on it.
I don't wan't to see my sketch on the 2D, so I hide it in my 3D model .... and my dimensions disappear in the drawing.
I created a new drawing with the same 3D model ... and at this time, the dimensions are shown.
I copy the drawing parameter from the new draw to the old draw, I changed the size of the drawing to call a new "font". But I still can't see my dimension
And (of course) I don't really want to make a new draw.
Do you have any idea where the problem can be ?
please test following steps:
If the above procedure resolves the problem then old drawing contains some kind of internal error. I met similar problem when I opened Creo 3.0 drawing in Creo 8.0.
You can send files to PTC Support to confirm my idea.
You save my draw !!!!!
I see a close solution on this topic ... but I missed the "all" to enter in value
Thank so much @MartinHanak, it works good !!
