New to Creo and hopefully this basic. In a drawing, when I add dimension text to a dimension, ala Ø, it doesn't print in the pdf.
What am I doinf wrong?
In the PDF Export Settings window, try selecting Stroke All Fonts under the Content tab.
Thanks for the help.
if you are using Creo 4.0 then you can set drawing option symbol_font to LEGACY
Thanks for your help.
