I was hoping that I can get a little help with dimension tolerances. Basically what I am trying to do is collect all of the dimensions on a drawing and output the nominal value, the location, and upper tolerance and the lower tolerance. I have managed to figure much of this out and can get all the necessary information for dimensions that are displayed with their tolerances as long as the tolerances are not driven by a tolerance table. Now I would like to also get the upper and lower tolerance for objects that are displayed with only the nominal dimension as well as the upper and lower tolerances controlled by a tolerance table. Any help in this area would be greatly appreciated.
I have attached thecode that I am using to accomplish what I have been able to figure out.
Thank you in advance,
Scott
