Dimensioning Diameters in 2D Drawings
jmagill
This should be an easy question but I can't seem to figure it out. Whenever I try to dimension the diameter of a hole in a 2D drawing, it displays the radius as opposed to the diameter. How can I change this so that the diameter is displayed instead of the radius?
6 REPLIES 6
Select the desired hole feature in the model tree, RMB>Show Dimensions by View, select the view you want the dimension to appear on. Or if you choose to use created dimension, click on the hole edge twice before accepting the dimension, this will give you diameter rather than radius.
Yeah, click the edge of the hole twice and then click to drop the dimention. This got me at first as well.
On a similar note, when you are defining a revolved feature in the sketcher, draw your axis of revolution first and then you can dimension a diameter by clicking a sketched entity, axis of revolution and the same sketched entity again. This way when you use "Show and Erase" in a drawing and pick your revolved feature, you get diameter dimensions automatically, and you can then (assuming your sketcher dimensioning scheme is adequate) drive your revolve features from the drawing.
There is also a config option to help in having dimensions for a revolved feature be created as diameters without having to pick the axis, and the sketch twice. The config option is: sketcher_dim_of_revolve_axis yes If this option is set all dimensions created by Intent Manager to Axis of revolution will be diameter dimensions. Dennis
Thnx a ton for ur post.....I was lost trying to figure this out
