I have a problem with the following:
When I in my 3D model suppress a feature, then in my 2D drawing the dimensions related to that now suppressed feature won't disappear. Does anyone have an idea how to fix this?
Are you certain the drawing is fully regenerated and sheets updated to reflect the suppressed state in the model?
By chance does the message : Retrieved object was previously saved with display is prompted when opening the drawing?
if yes there is a chance that the option save_display was set to yes.
Browse this article for resolution: https://www.ptc.com/en/support/article/cs35913
I have created some holes and for some of them the dimensions disappear when suppressing, but for some of them they do not... It is very odd...
Now that you say it is odd, then i suspect a data drawing corruption.
Did you try the dtl option update_drawing all?
shown model dimension will disappear
created drawing dimension will not disappear.
