Direct Diameter representaion on the drawing
AraviK1
Hi folks,
How to place Diameter dimension directly on the drawing instead of Radius without edting.
At present i am doing like using this "@O"
Can anyone help me?
AraviK
AraviK1
(To:AraviK1)
Got the solution. Thanks HatimAbdul.
HatimAbdulSilver
123 posts since
May 16, 2008
You can eith delete it and recreate it or you can select the dimension, right-click. From the popup menu select (edit attachment). Click twice on the arc/circle and middle click to obtain the diameter dimension (rad dimension is by one click on the arc/circle).
AraviK
AraviK1
(To:AraviK1)
HatimAbdulSilver
123 posts since
May 16, 2008
AraviK
